Author Topic: X-mas electrical gremlin  (Read 353 times)
Offline C-Diddy
« on: Dec 18, 2020, 07:54:37 pm »
Hello all, long time no post. A while back, my cruise control stopped working. Took it apart, rubber still in good condition, worked with straight battery power. Wasn't too worried as i figured it was a short somewhere that i'll eventually get to :heh:. Now, my 12v cigarette plug and windshield wiper sprayer, and door/courtesy lights have stopped working as well, at the same time. I believe it happened after i was using a tire inflator out of the cigarette plug. I still have wiper function, never had intermittent wiper since i bought it, just high an low (not too worried, but would be nice to fix). I'm looking for help on the  windshield sprayer, as this has become a safety issue while driving. I checked the fuses in the engine bay and driver's and passenger's kick panel, and all is well. I'm willing to pull the dash if i must, just looking for starting points before i get that far. Happy holidays
1984 Celica GT w/GTS wheels
LCE EFI Pro cam
LCE ported Throttle body
Lightened Flywheel
Doug Thorley Header to full 2 1/4" exhaust
PLX Wideband O2 sensor
AutoMeter Vacuum gauge
'82 Supra AFM
Koni sway bars front & rear
Tokico Illuminas all the way around
Whiteline lowering springs all the way around
Flexi-Sealed sunroof
Celica Inspiration
Re: X-mas electrical gremlin
« Reply #1 on: Dec 19, 2020, 05:43:17 pm »
Have you checked the fusible links? They're the bits of wire that go from one spade connector to another in the engine bay fuse box.
« Reply #2 on: Dec 21, 2020, 12:57:59 am »
Fuse links and check/clean ground points. That would be a good start imo.
