I recently acquired a 1985 Celica GTS that needs a lot of work, including an engine rebuild. I rebuilt the rack and pinion because it was leaking badly through the input shaft seal. Changing the power steering fluid that was in the system to the recommended ATF did not help. Well I lost one of the inverted flare fittings. I need the smaller one that goes between one of the hard lines and the rack and pinion, not the larger one that goes between the lines coming from the power steering pump/fluid reservoir and the rack and pinion. I was wondering if someone has one they can sell me. I haven’t been able to find anyone that sells them online. If not, can you confirm if this fitting can be found on other Toyotas of that year (Camrys, etc). Did all camrys come with power steering if the Camry has this fitting? Worst case I can pick one up from the junk yard.
