'83 and '84 both used the same EFI system with a vacuum advance distributor, so I believe they should work. '85 got the electronic advance distributor and a knock sensor, which is not backwards compatible. Could you send a photo of the connector socket on the ECU just to be sure it will at least be physically compatible? There should be a single-piece receptacle for two plugs. '85 ECUs would have a receptacle for three plugs, for reference.
The A/T variant should also work fine; when my car had the 22R-E, it was A/T, but after a 5-speed swap, I changed it for an M/T variant ECU and it was compatible.
By the way, I'm not sure that's the correct part number. Usually a Toyota part number is formatted like so: 89561-14172. Five digits before and after the hyphen.
