This is my 1982 Celica.
I paid $800 for it but the 21R was too slow so I sold that and put a 3SGE in it.
Due to the factory ECU not liking individual throttle bodies, I am using a Haltech Elite ECU and wideband o2 controller.
The engine is mounted using 2S engine mounts, and engine/gearbox crossmembers from my SA63. The sump has been modified to fit I am using the original power steering setup and most of the RA60 cooling system, the fuel system uses a modifed 22RE fuel tank from an RA65
Specs:
Engine:Haltech Elite 1000 ECU with CAN Wideband o2 controller
RA60 Radiator, 2x12" thermo fans. SQ engineering water outlet
AE111 4AGE 20V throttle bodies with 100mm velocity stacks
SQ Engineering ITB manifold and throttle linkages, SV21 Camry throttle cable
RA65 fuel tank, AEM 320LPH fuel pump and SARD fuel pressure regulator
DrivetrainSXE10 Altezza J160 6 speed (Aisin AZ6)
SQ Engineering shifter housing relocation kit and J160 to W58 speedo drive
SuspensionStock, parts on order but will be using 8/6kg springs, with KYB AGX dampers front and rear
SSR Formula Mesh 15x7 & 15x8
BrakesStock for now, looking for upgrades
