Hey all, I'm having a weird issue with a hesitation on my 85 Celica GTS. I'll go ahead and list off all the parts I've put on down below. I'll also to get a video of what it's doing tomorrow, as well as a walk around of what all's been done.
The hesitation is rhythmic, and it only happens when the car has been driving for a minute, and it only happens on WOT. It like revs but there no power, and then it rhythmically jerks, like baaaaa- baaaaa- baaaaa- almost EVERY TIME at around 3k RPM.
It also pops down low around like 1000-1800 RPM or so when you first start trying to drive it. It idles great when you first start it and even when it gets up to temp as well. No misfiring, surging, or anything of the sort. (It used to misfire bad before some of the ignition and fuel related parts I put on.)
Fuel System: New 60 GPH fuel pump, fuel filter, fuel pressure regulator, and I've run a couple different Lucas injector cleaners through it like 5 times. (Side note, it doesn't care what octane fuel you use either.)
Ingition: All new dizzy stuff (Cap, Rotor, and O ring), coil, NGK plug wires, and I had NGK V-Power plugs in there, but it overheating all the time, and the bent valve it had kinda made those die really quick. So there's a set of NGK G-Power plugs in there right now. I ordered V-Powers and the G-Powers came in and I was already home and I wasn't about to drive 30 minutes back to that store I bought them at so I just used them anyways (Lemme know if those would be an issue. It's run with them just fine before this started happening.)
Sensors and Electrical: All new OEM TPS, a new Bocsh O2 sensor (it's a one wire, idk if that would make a difference. It was acting up before I put the new O2 sensor.) I have a new TPS plug as well, but I haven't put it in. The old one falls out and it's held in with zip ties at the moment.
Engine: I've checked the timing chain and it's brand new. All the guides are literally mint and the little tensioner works great too. It's set properly as well. I did a full head gasket on it, with new gaskets on everything that was removed. I also had the head rebuilt and got 1 new intake valve (because it was bent) and 4 exhaust valves (they were mushroomed out)
Other: New clutch, New battery, New alternator, New Rad, and I saw that the set screws for the throttle body are missing. So I put in new screws for the throttle body, the one that keeps it from sticking (the one that you use to set the TPS) and the set screw little return thingy that you can push down on the back of the throttle body I replaced too.
The things that've been put on since the hesitation are the O2 Sensor and TPS. And the last thing I did before it started having this hesitation was the fuel pump (and we know what happened with that).
So I'm eye-balling the ignitor, or a sensor I could've missed, I'm gonna get some new vacuum lines and a PCV because it looks like garbage and leaks bad. Something MAY up with the fuel pump still. After I replaced the fuel pump it worked for about a month, and then it started this hesitation.
Lemme know what you guys think. I'll post a full video cold starting it, showing warm idle, driving it, and hopefully getting it to misbehave so you can see what I'm talking about.
Thanks!
