So, strange development this past holiday weekend. I noticed my idle albeit smooth was a bit lower than normal, low enough to stall once going from neutral to drive. I also noticed a light nails on chalkboard almost belt squeal type of noise from the engine. I stopped, popped the hood, assumed the idler bearing was going, gave it a couple hard revs while standing over the engine and it just died. No fowl noises, it just cut off and wouldn’t restart. I popped off the dizzy cap and found this and a code 6 dizzy code.
Firstly, the chain and guides are fine, so i’m hopeful that it is just a roll pin on the rotor shaft that went. Nothing sounds off when I try to turn it over like there is any less stress on the rotating mass like a broken chain. So in short, I hope a new dizzy will get me on the road again.
Secondly, the code 3 is still intermittent. I wonder if the dizzy pickup coil has been the culprit for this igniter code 3 business.
