Alright, its been a hot minute. I've been a little busy in some ways, and a little lazy in others. But my semester has ended so I have a good month to try to make some serious progress on my car for the first time in ages. So I bought a 2009 camry to replace my ranger so that should solve my daily issues. So lets dig in shall we
To be completely honest, I did not get much done in the time I haven't posted an update. So I stated by rebuilding my rear LSD and that was way more than I bargained for. Now I know that seems obvious but I still wanted to give it a try. Sadly I didn't take many pictures but I do have a few
As you can see with the coast pattern, this diff needed a rebuild. I got this 7.5" lsd from ebay with unknown miles on it. But I swapped it in as is almost two years ago.
So I got the wier rebuild kit and it is a very good kit don't get me wrong, however I am not experienced enough and ultimately brought my diff to a shop to have them fully rebuild it. I couldn't set the proper preload for my pinion no matter what shims I used, so I gave up.
Turns out my pinion shaft was too worn out along with my axel shafts, so they are machining sleeves to fix the issue.
After that I have been trying to make my headers as previously stated. I have been practicing my tig welding so I should have a decent base before my friend does the finishing welds for me. So I bought this header kit:
I also went out and bought 1" 5/8 pipe insulation and metal coat hangers to help me roughly mock up my headers
With this I have been cutting, measuring, checking, and rinse and repeat. I am going to reroute my power steering lines to allow for more room for my headers. The goal is to try to make them equal length, but it's not necessary just a nice plus. I also believe I bought the last of the major parts I need for my build to get the engine running in the car.
Speaking of the engine, I go the back in February and it made 394.5 bhp and 376 lb-ft to the crank!!! I have videos of it running on the engine dyno if anyone wants me to post them and send a link. I'll post a pic of the dyno graph when I get a chance but I have been dying to get driving again, even though I have been procrastinating finishing the car.
Overall I hope to make some major progress and get to the UConn car show this spring, so if anyone else is in New England, I hope to see you there
P.S. I don't know why the pictures are huge
