Author Topic: 84 GT-S 22RE Engine explosion  (Read 332 times)
Offline thespwilson
« on: Jan 20, 2022, 02:19:41 pm »
Alrighty so as I posted in the introduction I recently acquired a pair of 3rd gen celicas. The track car has a rod slung through cylinder #2 and will need to be replaced. The car has all the options that I can find for a stripped down car built exclusively for road course (mega squirt, traqdata, LC performance goodies, flame-thrower HV, monster radiator/oil cooler up front, beautiful cage/safety equipment, adjustable coilover, huge air damn, bigger brakes, brake diverter valves, and magnesium wheels).
As far as replacing the 22RE motor, I know I'll be rebuilding a few of these as the years go on- but I want to get a running engine in the track chassis ASAP. Any suggestions on pulling the motor with a running donor block; anyone use junkyard motors? I plan to start to stockpile a backup 22R engine and build up properly.
@thespwilson
Offline thespwilson
Re: 84 GT-S 22RE Engine explosion
« Reply #1 on: Jan 21, 2022, 12:36:01 pm »
Quick update, I assume I have an "early" 22r block and will be hunting a spare motor (might order a crate engine and some shops will trash the 22r block and only want the crank and other parts they can reuse).
@thespwilson
« Reply #2 on: Jan 21, 2022, 03:03:19 pm »
Early motors are 84 and down please note you CAN NOT judge the motor year by the valve cover. 85 and later has a casting pad on the block as seen here. The deck heights are different so head bolts,and heads dont swap. timing covers are different timing chains ect.
I would say the later engines are going to be more plentiful. You can swap the entire engine if I'm not mistaken but I think you need to swap at least the distributor, maybe the throttle body as well? Injectors can be different too on the later engines. I think they may have even used resistorless injectors at some point. I hope this points you in the right direction.
« Reply #3 on: Jan 21, 2022, 03:49:32 pm »
To swap to a later engine and keep the 84 ECU, you need to swap distributor and throttle body at minimum. If the engine is from a pickup, need to swap the oil pan and pickup tube. If the engine is 88 or newer, swap injectors.
Offline revvhappy
« Reply #4 on: Feb 14, 2022, 11:59:40 am »
Are you in Alabama?
I will be pulling a non-running 22re out of a 1985 Celica GTS this week in the Atlanta area. I have no idea about its history. If you would like it for parts and want to make a 2.5 hour drive you can have it free.
