Welcome,
Guest
Login
or
Register
Home
Help
Search
Members
Login
Register
Celica-GTS.com Message Forums
General
General Discussion
Help with a 1985 Celica GTS Convertible
Print
Pages: [
1
Author
Topic: Help with a 1985 Celica GTS Convertible (Read 138 times)
arexiiiw
Newbie
on:
May 24, 2022, 01:03:06 pm »
I sure need some help.....I have electrical problems...When driving....just fine...all is working GREAT...the engine will just die...NOT a fuel, fuel pump problem or fuel filter problem.....electrical......To re-start the car.....when you turn the key the engine light comes on...it will start...if the light is not on the engine will NOT start....To the shop...replaced the ignition switch...same thing still persists. The mechanic says its the Open Circuit Relay...where is it? He can't seem to find it.....What else would you suggest checking..
Logged
ozzie
Senior Master
Re: Help with a 1985 Celica GTS Convertible
Reply #1 on:
May 24, 2022, 03:58:43 pm »
The circuit opening relay, I believe, is mounted on the passenger's side inner fender, and I think it sits upside down.
Logged
1933beer
Full Member
Reply #2 on:
May 24, 2022, 06:16:47 pm »
I think your right ozzzie. I have had problem on our supra but it was not intermittent.
I would check grounds make sure they are good.
Logged
Print
Pages: [
1
General
General Discussion
