Author Topic: V-8 Mk2 Supra  (Read 3569 times)
V-8 Mk2 Supra
« Reply #15 on: Sep 11, 2003, 01:10:25 pm »
I am not too sure about that. The first GTS was actually a dealer option (Flares, rims etc)   However, if it is true that the 82 GTS was IRS, then it would prove that the IRS could be put on a GT.  I may be wrong so dont think I am putting down your knowlege
Offline NightCelica
V-8 Mk2 Supra
« Reply #16 on: Sep 11, 2003, 06:30:51 pm »
The only the 7M-G(T)E had head problems because of the NEW 24V head, no M-series engines before the 7M had any head problems, non not the 3M, 4M, 5M single cam, 5M-G or the 6M.  It was only the 7M engines that had the head problems.
V-8 Mk2 Supra
« Reply #17 on: Sep 11, 2003, 11:24:12 pm »
Oh, well thats good to know.. i wanna get a mk2 supra and get a 6M-GE for it..
Offline Celicasrule
V-8 Mk2 Supra
« Reply #18 on: Sep 12, 2003, 12:48:18 am »
I had the pleasure of driving a 91 supra TT "built" close to 450 rwhp. It was FUN.
V-8 Mk2 Supra
« Reply #19 on: Sep 12, 2003, 12:51:57 am »
Yeah there is nothing like feeling your body sink into the seats.  However my experience was in a modded Nissan 300Z.
Offline Celicasrule
V-8 Mk2 Supra
« Reply #20 on: Sep 12, 2003, 12:53:37 am »
That works too. If we put turbos on our cars will it trow us back into our seats?
V-8 Mk2 Supra
« Reply #21 on: Sep 12, 2003, 12:54:41 am »
Hell yeah it would, that is why I want one..
Offline Celicasrule
V-8 Mk2 Supra
« Reply #22 on: Sep 12, 2003, 12:55:50 am »
Would a Twin turbo celica even be possible?
V-8 Mk2 Supra
« Reply #23 on: Sep 12, 2003, 12:57:07 am »
Not really, there would be no room for it, but it would be one hell of a badass car
Offline Celicasrule
V-8 Mk2 Supra
« Reply #24 on: Sep 12, 2003, 12:58:53 am »
We can always make room. Would you have to order 2 turbo kits or 1 kit and 2 turbos?
V-8 Mk2 Supra
« Reply #25 on: Sep 12, 2003, 01:00:31 am »
Hmm, good question. But just remover the hood for more room and make a little tower of turbos
V-8 Mk2 Supra
« Reply #26 on: Sep 12, 2003, 01:01:32 am »
Its been done to an AE86 so see no reason why. I was just reading about a TA22 with a 1UZ twin turbo. http://members.optushome.com.au/activepete...bo/jamiett.html
Now when that is properly turned that should be a beast to drive.
Offline Celicasrule
V-8 Mk2 Supra
« Reply #27 on: Sep 12, 2003, 01:01:46 am »
It'd be worth it to kick a ferraris but with a 20yr old car.
V-8 Mk2 Supra
« Reply #28 on: Sep 12, 2003, 01:04:39 am »
You could beat pretty much any car if you tuned it right
V-8 Mk2 Supra
« Reply #29 on: Sep 12, 2003, 01:04:44 am »
If I was going to do that, I would use the 1JZ since it would be lighter.
