Author Topic: Camshaft For Efi  (Read 1253 times)
Offline 85blackGT
    • http://www.cardomain.com/ride/444766
Camshaft For Efi
« on: Sep 09, 2003, 09:10:04 am »
OK so i got my new performance head,ported,oversize valves all the good stuff but now i dont know what to get for a cam,i dont care about emisions as long as the car runs better than stock,and its an efi so its gotta work with it,do you guys think the TRD stage 3 will be too much for it,i have headers,2 1/2 pipes,and the flow master,for the intake im saving for that oversize tb,but i have a cold air intake(custom)and ramair,please guy let me know,thanks.
1985 Celica GT
Offline Bridge
  • I get all the girls
    • Facebook Profile
Camshaft For Efi
« Reply #1 on: Sep 09, 2003, 09:50:52 am »
You can acutally go higher than a TRD stage 3 if you want. But i think TRD stage 3 is a good deal unless you want to go for the LC engineering Cams. You can get a rough idel can and add a lot of HP!
-2002 Subaru WRX-
Offline NightCelica
Camshaft For Efi
« Reply #2 on: Sep 09, 2003, 10:23:46 am »
Cam you say!   You have a EFI thats good, but beware you need to stay under
280 duration, the EFI does not like to work with anything higher, vacuum problems araise. Plus even at the durations like 250-280 you should readjust the AFM for the right A/F. This is esp. true with all the other head work that been done, you might look into the idlea of larger injectors now.
Remember if the work was done right your head could flow as much as 200% more air now than stock.
                                           All information was gainned at Toysport.com  under there 20/22/22r(t)e engine section.
Offline toynado
Camshaft For Efi
« Reply #3 on: Sep 09, 2003, 04:21:20 pm »
cam page
how much larger are your valves?
as you increase the cam's 'cram'
you lose mileage and some low end for higher rpm hp
trd makes nothing themselves as far as i can tell
they just re sell stuff that's usually already on the market
they hav nothing cheap
that's y i never buy their stuff
i forget who made their cams, maybe more than one manufacturer
cam specs can be deceiving
no one lists their profile...
ramp speed is important...
they don't even have dyno graphs...
wut a sorry way to market hp mods  :angry:
i wouldn't get a regrind before you understand the geometry involved
get a 'new' cam, not a regrind
Offline C-Diddy
Camshaft For Efi
« Reply #4 on: Sep 09, 2003, 05:23:21 pm »
I have the LC Engineering EFI pro cam in my 84 GT and it is just right. I like the idle and you can really notice the response. I really don't know much about the other brands, but i can say that you will not be disappointed with this cam
http://www.lcengineering.com/Camshafts.htm
1984 Celica GT w/GTS wheels
LCE EFI Pro cam
LCE ported Throttle body
Lightened Flywheel
Doug Thorley Header to full 2 1/4" exhaust
PLX Wideband O2 sensor
AutoMeter Vacuum gauge
'82 Supra AFM
Koni sway bars front & rear
Tokico Illuminas all the way around
Whiteline lowering springs all the way around
Flexi-Sealed sunroof
Celica Inspiration
Offline Bridge
    • Facebook Profile
Camshaft For Efi
« Reply #5 on: Sep 09, 2003, 06:31:06 pm »
Since you already have alot of head work done to your engine i'd go with a bigger cam than the EFI pro. You engine can handel a bigger cam. I personally dont mind rough idel... i think its cool actually But i guess other people hate it.
TRD's cams ARE cheaper then LC's cams... Stage 3 would be good... but if you want a huge cam i'd go with LC's stage 3 or something. The 22RE stock can handel 282 before the valves his the pistons... so keep that in mind also.
-2002 Subaru WRX-
Offline flyingbrick
Camshaft For Efi
« Reply #6 on: Sep 10, 2003, 12:55:48 am »
I'm almost done rebuilding my motor. I'm using a pretty much stock head(just a bowl job and a quick blend) and am installing a crane stage 2 I'll let you know how it works.
Advertised Duration
Int/Exh Duration @ .050
Int/Exh Lobe Separation Gross Lift
272 / 282  224/234  110  430/444
Offline 85blackGT
Camshaft For Efi
« Reply #7 on: Sep 10, 2003, 04:18:05 am »
Thanks guys,i think im going with the lc cam,so what do you guys think? stage 2 or 3 from LC,also any good brand for injectors(balanced),thanks again.
1985 Celica GT
Offline NightCelica
Camshaft For Efi
« Reply #8 on: Sep 10, 2003, 12:11:02 pm »
Injectors go with RC Engineering   http://www.rceng.com/
Thier the best I found   But thats me!
Offline toynado
Camshaft For Efi
« Reply #9 on: Sep 10, 2003, 04:49:41 pm »
depends on if you mind getting less mpg and more hp...
i'd buy injectors at the junk yard
then take em to the dentist to be soaked in the ultrasound for a few...
 :blink:  :rolleyes:  :D
Offline Bridge
    • Facebook Profile
Camshaft For Efi
« Reply #10 on: Sep 10, 2003, 06:07:17 pm »
You cant just walk into a dentist and ask them to clean your fuel injectors... Or can you?
-2002 Subaru WRX-
Offline toynado
Camshaft For Efi
« Reply #11 on: Sep 10, 2003, 07:48:44 pm »
well, i walked into a wall once...   <_<
i'm sure this would work tho,
if you're elvis :ph34r:
do u know wut toyota means?
