Bring it on.
You asked for it
This was not written by me!!!!
Written by
Seto Kaiba"As for modifications I would make sure everything is in good condition stock
before you modify. Make sure all the suspension bushings are good and if
they are not that is a good excuse to install the Energy Suspension bushing
kit as it will help eliminate deflection in the chassis. My car had worn
bushings in the rear control arms and I would get massive wheel hop when the
tires lost traction whether I was drag racing or drifting. But after
everything is in good working order I would get the items they are starting
to discontinue first as that will save you a lot of headaches down the road."
"The thing I would get first are struts and shocks as they are being discontinued and are running low in peoples inventory. Koni adjustables, Tokico Illuminas, and a few others are going away and are the best you can get. I have the Tokico Premium Performance struts and shocks as they are really stiff but aren't
adjustable. They are relatively cheap though at around $60 front and $35
rear compared to the Adjustables running close to $70 front and $85 rear. I
have heard that some people were able to adapt AE86 Corolla struts and
shocks but haven't confirmed it myself. Also some people have used mid-80's
Camaro shocks in the rear. But when modifying I always start at the back and
work my way forward. Since you have a GT that means you have the 6.7" solid
rear axle. A popular upgrade and needed with a lot of power is a 7.5" Supra
rear end from a late 70's to around 1981 Supra. It can handle way more power
than the 6.7" as the spider gears on the 6.7 are very prone to breakage. You
should start with suspension and brakes first as with the added power from
the 1GGTE it will over power the suspension and since you will be able to
attain higher speeds faster you will eventually need to slow down. I would
recommend a good adjustable strut/shock or if you want something stiff and
cheap use the Tokico's I use. Then get some Eiback springs, or better yet
get the Ground Control front coil-over kit and some custom rear springs
(call 785-437-2266 for custom rear springs). My setup is the Tokico Premium
Perf with Ground Control coil-overs and custom rears that have about 75%
stiffer spring rates than stock."
There is much more(I have to look
), but this should be enough for now.
Enjoy the read!
