Author Topic: Comprehensive Sra Suspension Tuning Guide  (Read 75192 times)
« Reply #45 on: Aug 12, 2006, 06:03:05 pm »
*facepalm* I've been pushing PST for more than a year on this site, because of fitment, availability, and 20 year warranty. It don't get any better than that. ;)
« Reply #46 on: Aug 26, 2006, 07:12:24 pm »
so did your bushings for your sway bar to bracket fit perfectly? :P
« Reply #47 on: Aug 26, 2006, 07:57:18 pm »
Yes they did. :P
Offline 85celisupra
« Reply #48 on: Nov 22, 2006, 02:15:18 pm »
i like the light idea of getting the blues and the dobinsons springs up front, but what about the back, does tokico carry rear blues and does dobinson carry rear spring for a 85gts?
does this stuff in the links apply to only gt cars or are most of the parts were talking about interchangeable?
i also would like to get a set of sway bars, whats a good brand to buy? is it like allmost everything else, you get what you pay for?
« Reply #49 on: Nov 22, 2006, 04:26:00 pm »
Dob used to carry rears, but I haven't seen them for sale for awhile... You can use any rear shock designed for the rear of a Ford Focus. I've got a set of KYB AGX's in mine and they're great.
Offline SonyPete
« Reply #50 on: Nov 22, 2006, 05:01:10 pm »
Quijk question, the rear focus shocks, are those a shorter stroke then the stock IRS shocks?
1983 Celica GT with Built-for-Boost 22RE
Current Mods:
- Forged CP Pistons, Prepped Rods, ARP Head Studs & Rods Bolts
- Lightened & Knife Edged Crankshaft
- Compcams 127-4, 82' Supra TB and AFM
- DT Header and 2.25" Under Axle Exhaust
- 12" Electric Fan
« Reply #51 on: Nov 22, 2006, 09:53:40 pm »
to my knowledge, not the ones I have.
Offline celicaskater
« Reply #52 on: Mar 08, 2007, 05:27:50 am »
Ok, so i have decided the next heavy mod's that I am going to do is the aggresive street suspension setup.  I do have an IRS but I am going to do the same thing.  Paradise racing coilovers up front (or Ground Control).  CSS spring in the rear with an inch drop to avoid negative camber.  My question is do I have to upgrade the shocks and struts to achieve these modifications?  Thanks...
1985 celica gts
5 Speed
Modifications-
Complete performance engine rebuild
Custom Short Shifter
Supra AFM with K&N filter
5% tint
Kenwood/sirius deck
JL 10" sub
1100 watt amp
Infiniti front speakers
Custom Strut Bar
Sportmax 002 wheels 16X8
Thorley Header w/ 2.25 Exhaust to Magnaflow Muffler
Modifications to Come
Complete suspension rebuild
Oil pressure gauge and Air/Fuel Mixture Gauge In A-Pillar Pod
supra throttle body
Offline kevindee79
« Reply #53 on: Mar 08, 2007, 06:19:39 am »
i want to upgrade my suspension too.  keep me updated on how your setup goes.  and how much you spent.
i personally would upgrade shocks and struts while im at it.  i know rapidchimp has the adjustable setup that should work for us.
« Reply #54 on: Mar 08, 2007, 05:18:50 pm »
For the rear you can get KYB AGX rear shocks for a Ford Focus, 2002-2004. For the front you can get the *rear* struts for a second gen MR2 and put spacers in the bottom of the strut tubes (big washers work well).
« Reply #55 on: Mar 08, 2007, 10:50:41 pm »
I know what I can do but do i have to do that?  in other words do I have to replace the shocks and struts when i do my coiloverrs and springs?  I am going for low cost...
1985 celica gts
5 Speed
Modifications-
5% tint
Kenwood/sirius deck
JL 10" sub
1100 watt amp
Custom Strut Bar
supra throttle body
« Reply #56 on: Mar 09, 2007, 12:04:45 am »
It's a bad idea to not match springs with dampers...
Offline TRD22R
« Reply #57 on: Mar 12, 2007, 03:10:04 am »
OK, a couple questions from my Celica suspension novice self  :wall: relating to my '83 RA64......First, do the Tokico HP blue front struts come with the spindle the hub and rotor mount on? I'm looking in my trusty Haynes manual, and it shows the strut and the spindle as one unit. Second question: I'd like to use the Ground Control coilover kit  http://www.autocarparts.com/part/408/37  ......are any modifications to the Tokico struts needed to make the kit work? Thanks in advance for your advice. :thumbs:
« Last Edit: Mar 12, 2007, 03:12:42 am by TRD22R »
1983 Celica GT
-Custom CAI
-Cherry Bomb muffler w/twin outlet tip
-Red Eurolite Gold Underglows
-Ford Racing Stainless Steel Hood Pins W/Lanyards
-15x7 American Racing wheels
-Pioneer DEH-P3300 CD Player
-Kenwood Speakers
Next....More high performance engine, suspension, and exhaust parts, new paint job.
« Reply #58 on: Mar 12, 2007, 04:23:03 am »
The Tokico's are strut replacement inserts. Depending on if they've been done before, you'll either have to pull the old inserts out or take the original struts apart. Then you install the replacement inserts into the strut tubes and lock em in with the gland nuts.
Offline TRD22R
« Reply #59 on: Mar 13, 2007, 02:31:33 am »
Oh, I see....mine are the *cringe* originals (so are the rear shocks :o) .....after 24 years and 159,000 miles, I figure since I'm replacing them anyway, why not upgrade a little? :thumbs: Thanks for the help!
« Last Edit: Mar 13, 2007, 02:32:51 am by TRD22R »
1983 Celica GT
-Custom CAI
-Kenwood Speakers
