things you need at the junkyard
-motors and regulator
-wires
-wire harness
-door panel
tools and other things you need
-electric tape
-wires
-fuse holders
-wire cutter
-relay and harness
-small screw driver
well first of all my car is an 1983 toyota celica gt the wire harness i got from the junkyard was from an 84/85. i thought all the harness were goin to be the same so i got them. turns out that they were compeletly different. but with the help of flyingbrick i was able to make things work.
first of all try not to splice any wires like i did o_0 you can use a small screw driver to pop the terminals out of the harness.
next you should test out the motors if they work or not. by connecting one wire to the + of the battery and - on the battery and check if you see any movement if nothing the motors are probably broken.
now to take out the manual windows.just take out the handle for the window, armrest, door panel and unplug the door light. take that plastic covering out. then there should be 7 screws there.
once you unscrewed everything you can pull it out.
now for the wiring. the pictures are from the Toyota Celica 1983 Electrical Wiring Diagram and Toyota Celica 1985 Electrical Wiring Diagram i think teran said if we posted where we got the picture its ok to post, if not ill take it down (just let me know, dont wanna get banned) =)
this is the wire harness on an 1982-1983
and
wire harness on an 1984-1985
this is what flyingbrick told me
15 of M is 7 of N
14 of M is 6 of N
16 of M is 3 of N. Goes to the passenger side its 16 of R is 3 of M
12 of M is 4 of N. Goes to the passenger side its 12 of R is 4 of M
13 of M is 8 of N. Goes to the passenger side its 13 of R is 8 of M
these should be all to make the windows work
for the side view mirror the colors should be the same so u can just match them up. i think they were Brown/Yellow, Brown/Black and Aqua/Red.
same with the door light Red and Red/White
that should make ur wiring complete
Now for the Relay
the relay i used is STANDARD part# RY116 and its connector or harness is made from STANDARD too part# S-654
the relay should have numbers on them 30, 85, 86, 87 and 870. total of 5 prongs. but you are going to use 4 of them. you can ignore 870. the others you need.
well if you get the same relay and connector i got:
30 is a red wire connects to the battery
85 is a light blue wire connects to a fuse like the horn or radio
86 is a green wire connects to a ground ( body or battery )
87 is a yellow wire connects to the yellow and red wire on 7 of N harness
i used fuse holders on 85 and 30
your relay should be wired similar to this. ( sorry if the pictures sucks lol )
that should make your windows work.
